Something that is supposed to hold water isn't and it's leaking into the cylinders but heck you knew that already. Could be a cracked sleeve, head or block, could be a bad head gasket or maybe monkeying around one of the sleeves moved, don't know if this is a wet sleeve or dry sleeve engine. If it's a wet sleeve it could be leaking at the seals, if it's a dry sleeve it might of moved enough and is preventing the head gasket from sealing. Before I tore it apart again I think I would try spinning it over with the plugs out and see if water comes from all cylinders or only one, an alternative would be to pressurize the cooling system with the plugs out to see if the water is localized. Are you getting any water into the oil? Something else to look at and might help you figure out where it's coming from.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
