Posted by rustyfarmall on April 17, 2012 at 13:49:48 from (216.248.71.224):
In Reply to: 263 Gas Motor Missing posted by BigBob706 on April 17, 2012 at 11:54:08:
Do a full tune up. Spark plug wires, distributor cap, rotor, points, and condensor. Might even want to replace the ignition coil, and even though you already changed the spark plugs, don't rule out the possibility that new plugs might not be up to snuff. Also, ignition problems will quite often mimic fuel related problems, and vice-versa, so make sure the carburetor is not set too lean.
Unless you are running that tractor full out, making it work as hard as it can, it will run just fine on the same gasoline that you use in everything else.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
