Posted by Janicholson on April 13, 2012 at 20:00:02 from (96.24.99.126):
In Reply to: alternator puzzle posted by notjustair on April 13, 2012 at 19:05:43:
The L terminal is the vertical part of the T shaped connector socket. The S terminal is the cross bar on the T. The lamp used as a "idiot" light in the L circuit. This lamp is connected with one lamp lead connected to the Alt L spade connector, the other lamp lead is connected to the coil (where the ignition power from the switch is connected. (if it has a ballast resistor, it is connected at the ignition switch side of that device.) If the use of a diode is chosen the diode is placed in the same place as the lamp, with the band end of the diode toward the alternator. If a resistor is used, (10 ohm) It is placed in the same way as the light. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
