All that other advice you need to follow, but be sure the transmission housing is not flooded. Remove the bottom drain plug and see if any water comes out. If yes allow all the water to drain out before replacing the plug. You then need to consider cleaning and replacing the transmission housing of the wet oil crud ant there are plenty of post on here on how to do that. The reason I am saying this is that the seals are not designed to withstand constant pressure but to minimize oil loss due to splatter. Normal oil level is below the seals. Since these old tractors gain water in the transmission when stored out in the rain (and then not run to dry it off), you might want to look into this issue before you replace the seals. You can make a quick check of the oil level using the level plug on the rear of the housing under the belt drive.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
