Posted by TimWafer on April 06, 2012 at 12:34:20 from (69.193.106.146):
In Reply to: 656 front axle posted by TimWafer on April 03, 2012 at 16:23:43:
Still working on adjusting this axle. Pretty much have tried all the suggestions including bumping into a wall & driving it around a while with the clamps & pins removed. Also removed the spindle and replaced it with a 5 foot heavy walled pipe and pulled the end towards the rear axle with a come-along until the pipe was bending. All the while heating and hammering on the tubes. The tubes haven’t budged even a hair.
So finally have removed the entire front axle and stripped it down to just the outer axle tube and the two adjustable insert tubes. Tonight will rig up a better way to heat it and can at least get a good swing at all sides with a sledge now. Then may weld up some brackets so I can use a 20-ton jack to try and push them apart. I blew apart a 12 ton jack already but didn’t have it really squarely aligned hence the need for the brackets.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
