The cable will pull the lever on the governor till it hits a positive stop, that can be adjusted by the bolt on top of the governor. With a helper present, loosen the cable clamp, and manually pull the lever till you reach the desired RPMs, adjusting the bolt stop as necessary. When the RPMs are where you want them, and the throttle lever in the full/high position, tighten down the cable clamp.
If the spring is weak, it will also not allow you to reach high RPMs.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
