If you have a distributor you need to see if there's voltage to your coil. With the points open and your ignition switch in the on position you should have voltage on both small terminals on your coil. You need to use a volt meter or test lite. If there's no voltage you need to check for voltage at your ignition switch. There should be a wire feeding battery voltage to it. If there's voltage feeding the switch find the wire on your ignition switch that feeds voltage to the coil. With the switch on see if there's voltage on that terminal. If there's voltage there replace the wire from the switch to your coil. If there no voltage on that terminal replace the switch. Hal
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
