Posted by pete 23 on April 01, 2012 at 18:40:25 from (74.32.231.176):
In Reply to: 756 D Tach drive posted by flhr62 on April 01, 2012 at 13:05:11:
Only easy fix I can think of is if the drive end is worn off. It drives from a slot in the center of the cam shaft gear and you turn the adaptor housing in as far as it will go gently, then back it out to align with the tach cable. If that end is worn off you could probably build it up or maybe just try readjusting the depth it is screwed in. Other wise,reduction gears stripped out. Usually, the problem is that the gear actually turns but it won't turn the cable as the end of cable is worn out and the square drive inside stem is also worn. I have pinched a few together over the years, not necessarily on that model.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
