Someone put the distributor in "wrong" and moved wires to make it work. Older engines are simple and it happens more than you think. It's been 35 years sine I had a distributor out of a H or a M. Distributors usually either have a gear on the end and you can put them in as many different ways as the gear has teeth, other have a tang on the end they go in right or 180* off. I'm almost thinking the H has a tang drive, if it's off but not 180* off it means the gears in the front are not timed "right" How to fix- rotate the engine until the timing marks ling up at TDC compression figure out were the distributor is pointing- make that #1 then place your wire in firing order by rotation.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
