Posted by wisbaker on March 19, 2012 at 13:17:04 from (207.118.181.99):
In Reply to: 400 LP questions. posted by Fullers Farmalls on March 19, 2012 at 12:18:34:
Procedure varies form unit to unit and what you're local authorities will allow. At worse you'll have to get your LP tank set up with a pump and vapor return line. With that set up you hook two hoses from the tank to the tractor open the valves on the tank and tractor and turn you pump on pumping liquid propane into the tank and allowing gas/vapor back. Everything on the tank needs to be explosion proof wiring. I have used other systems where we vented the vapor return to the air but I don't know if that is allowed any more. No you can't use natural gas, it won't liquefy, your propane system won't handle CNG and you'd need a compressor to to increase the natural gas to a usable pressure. The tractor pulls liquid propane out of the tank through a heat exchanger that turns it into gas that mixes with the air at the carburetor.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
