First pull the plug next to the P/S pressure line and install gauge. Turn the steering wheel to the lock and hold it, and note the pressure. Should be 1100-1500 PSI. A) Gauge fluctuates/oil foamy-it's sucking air someplace. Is it full? B) pressure within specs- look externally for the problem, possibly stiff joints in wide front axle,or steering column u-joints. C) Low pressure- you need to isolate the components to determine if you have a low pressure problem due to by-pass in the steering unit or pump. You will have to fabricate some fittings to put a gauge in the pressure line.You need to have a valve between the gauge and steering unit. Engine idling, slowly close the valve and see if the pressure comes up. Do not spin it shut in case the relief valve is stuck closed. You do not specify if it steered before you changed the oil, But I think the steering would be acceptable in the 900-1000PSI range. (with valve closed). If the pump and related components are tight, it will climb to 1500PSI pretty quick. If the pressure continues to climb above 1500PSI as you close the valve, stop the tractor and service the relief valve. Obviously, if the pump is putting out this kind of pressure, the trouble is most likely in the steering unit. Get a 460-560-660 I-T manual, it will tell you how to service it.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
