I have a super A and I will second that ground speed issue.
With rocky new england soil, plowing a new area, even in first at low idle, can get pretty painful.
(in fairness to the machine, my low speed may have been set to high - I don't know)
I can't imagine having bigger wheels - it'll definitely be worse.
Aside from plowing, the speed hasn't been too much of an issue for me.
On my super a - the pivot pin on the front axle - that attaches the tractor to the axle - the weld was broken on the axle where the pin mounts through. Tough to spot so look closely.
I'd expect the hydraulic pump to be leaking fluid into the crankcase, but not sure there's any way to find out other than ask the seller. If he hasn't fixed it himself, it probably IS. That's probably a $50 fix all said and done.
I'd also expect the steering to be very loose. Anything more than 1/4 turn of the steering wheel, before the wheels move, would be considered very loose. But again, that's normal wear unless he fixed it himself. Either way, it's an $80 fix.
Might try looking at the lights with the tractor off and after starting - see how much they change. My lights simply didn't work on mine (and I'm restoring it all now so I can't check) so I can't tell you exactly what to expect - but if they brighten up when it's started, at least it tells you the generator's generating. If not - figure anywhere from 50 to 150 to fix that. (might be converted to 12v alternator)
Take a close look into the gas tank - look for rust spots - check the bottom of the tank on the outside. Rusted out tanks aren't fun to fix. If it looks suspicious - figure 150 for a new one.
The little "tool box" under the seat typically rust out - 50 bucks if you want a new one.
Drive it in all gears - 3rd, and especially 4th will probably whine pretty loudly - that's normal. But listen for any clunking, grinding, skipping gears or otherwise mechanically bad sounds. Do the same with PTO - engage it and make sure it sounds normal. Any loud crunches or knocking, I'd probably just walk away.
If you can, hang some weight on the rear rockshafts and lift and lower it with the hydraulics - they should be smooth and fairly quick. If not - maybe an easy fix, maybe not - assume at least 130 for a touch control rebuild kit. (or just as much for a used hydraulic pump - depends on what the problem is)
Check the block carefully for any freeze cracks - along the flat sides.
The radiator mounts no the bottom of the radiator are a weak spot. There are two - they are studs coming straight down from the bottom of the raidiator into the front frame. Look around there for drips. If you find some - hard to say, but probably not an expensive fix - call it 50 bucks for pricing purposes.
Obviously blue smoke is burning oil. If you get a bunch on start up or with a change in engine rpm - it probably needs valve seals - a relatively big fix, but that's also something you can just live with for a while.
other than that I can't think of anything specific to them that would be a common problem to watch out for.
They're pretty solid machines.
Sorry for the mile long reply - I type very fast so I often type too much!
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
