Since both pedals are on the same shaft, I would first check the bushings for that shaft in both sides of the tranny housing. They either need lube (grease) or one of the spacer machine washers was left off causing either pedal to rub against the tranny housing. This would cause the 'click" noise, had the same issue on a 46 H that drove me crazy until I replaced the bushings, had the shaft turned & clutch pedal rebushed to match the shaft.
The grinding noise you will need to checking your clutch pedal free travel at the throw out bearing, sounds like when the pedal is released the forks are either still contacting the throw out bearing ( rubbing) or the set screw on the clutch pedal needs adjusted also.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
