Posted by Kevin Fritsche on March 11, 2012 at 13:24:06 from (70.241.79.223):
Hello, I apoligize in advance for the lengthy first post but here it goes. I am converting an "H" to 12 volts for my aunt. I read a lot of posts on here about the conversion but have some questions. I plan to use an Optima gel battery and will have to build a new battery box. It looks like width and height of the original box are OK but not the length. It appears it needs to be about 1 1/2" longer. Is there room to accomodate a slightly larger (longer) battery box? I will use a diode instead of the light in the alternator circuit. What amp rating does the diode need to have? I read these tractors were originally positive ground systems and the ammeter will read backwards which is easily corrected. How do you get the starter rotation correct? Some of the info I see is for the "M". Are the "M" and "H" electrical systems the same or close enough that the "M" info also applies? Will the standard pully on a typical alternator spin it fast enough to charge effectivly? I will take pictures and try to post them when finished. Thanks, Kevin
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
