While many many many of the older 6 volt tractors were indeed Positive grounded (and then many switched to Neg at 12 volt except allllllll two cylinder Deeres 6 or 12 volt were Pos ground), theres no reason (if configured and polarized etc) they cant work at Negative ground. Way back before Neg became the standard Ford had a different idea then GM and Chrysler as I recall and there was some thought there was less corrosion where frame members were joined if Pos ground was used.
SPARK PLUGS they dont know or care if a 6 or 12 volt coil is what produces the several thousands of volts necessary to arc jump current across their gap. They fire at maybe 5000 to 15000 volts or so depending on the gap width and medium (fuel and compression) in which they operate NOT ANY 6 OR 12 VOLTS. They are designed to retain or dissipate x amount of heat to the relatively cooler head which is the plugs "heat range" and thats a mechanical and thermodynamic property and design cosideration NOT if a 6 or 12 volt coil is uded to produce the thousands of volts to arc jump current across their gap.
WHILE MANY OLDER 6 VOLT TRACTORS WERE 6 POS GROUND AND 12 WERE NEG, ITS NOT NECESSARY ANY 6 VOLT VEHICLE MUSTTTTTTTTT BE POS GROUNDED.......THE SPARK PLUGS ARE NOT NECESSARILY CONCERNED IF THE TRACTOR IS 6 OR 12 VOLT.........
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
