Posted by screwstick on February 29, 2012 at 09:24:59 from (174.24.8.24):
In Reply to: Cub tie rod adjustment posted by Travis Troxell on February 29, 2012 at 08:56:49:
The clamp is only for extending the rod out to match the extension of the axle. Tighten the clamp back up in the same notch that the axle is set to.
To adjust the tie rod, the socket at the end where it attaches to the spindle arm is threaded with a jam nut. Loosen the jam nut, and turn the socket in to the desired toe in. Adjust the socket to where you have the front of the tire 1/4" closer than the rear of the tire. The screw at the end of the socket should be tight enough to limit the play to a minimum with a cotter pin installed to keep it in place. There is no adjustment at the ball socket end except for shims to reduce play.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
