Yes it did. Mine is that way, but it is prone to foaming and continuous flow would probably do it in at some point. I have seen where several people have used the return at the bottom technique and it seems okay as well. I now have a separate 3 spool valve with a filter right after that on the way back to the tank.
For crawlers IH actually just recirculated the oil directly back to the pump. They use a check valve arrangement to keep the lines filled from the reservoir. (Crawlers need to work on steep inclines) Gets just a little warm but these pumps aren't fast enough to worry about heat. If the crawler doesn't heat up with a 82 GPM pump, a 12 GPM SMD is good to go.
If you do run a T down below, have the return line go straight through towards the pump.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
