Posted by SDE on February 25, 2012 at 21:12:46 from (174.124.49.15):
I made a shaft that is .003 larger than the crankshaft journals. I put the connecting rod in a vise and then removed shims until the shaft was tight in the bearing. I then turned the shaft with a pipe wrench. After removing the shaft, I would scrape the bearing. I did this until the shaft showed that it was making contact on at least half the bearing surface. Some had two more shims on one side than the other. I put them back so that each side had the same amount. This is my first time working with babbit bearings. Am I doing it OK so far? I saw in the archives that you install them onto the crank so that they are tight and then add a shim to each side until they are loose. Will the way I did it work OK?. Thank you Steve
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
