Posted by John T on February 24, 2012 at 05:41:29 from (66.87.4.142):
In Reply to: electrical problem posted by farmalmarkmark on February 23, 2012 at 18:24:50:
First of all "wiggling" is no substitute for what I recommend which is to remove,,,,,,,,,,clean and wire brush all shiny,,,,,,,,,and replace each and every battery and starter and switch and especially FRAME GROUND cable and connection then try it again.
If when you push the start switch the lights dont dim down and/or the voltage dont drop much the problem may be the start switch contacts are burned and pitted and resistive (but still could be maybe starter brush problem)
However, if the lights dim wayyyyyyyyy down and voltage drops drastically IF ALLLLLLLLLL CABLES N CONNECTIOSN ARE GOOD???? Id suspect a starter problem instead of the switch
Yes you can by pass jump the switch direct to starter but thats a HIGH current jump remember and requires heavy jumper cables and good connections
Id suspect a cable or connection or ground problem BEFORE the rest
Today's Featured Article - New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start
... [Read Article]
Latest Ad:
[More Ads]
