Use standard torque unless a special torque is given.
Taken from the IH repair manual GSS-1036-E W/Revision 2.
Special Torques (ft. lbs.)
Bearing cap bolt --------------- 80
Crankshaft pulley nut --------- 95
Flywheel bolts ------------------ 60
Thrust plate bolts -------------- 38
Idler gear shaft bolt ------------88
Crankcase front plate bolts --- 38
Crankcase front cover bolts -- 90
Connecting rod bolts ----------- *
Cylinder head bolts ------------115
Oil pump mounting bolts ------- 22
* Two types of 3/8" x 24 connecting rod bolts are used. These bolts can be identified by appearance and each type has a different torque specification.
1. The PLACE bolts has a head that is either "notched" or concave. Also the shank and thread diameter is nearly the same. This type attains its tension by bending the bolt head It should be torqued to 50 ft. lbs.
2. The PITCH bolt has a standard bolt head with a washer face. The thread diameter is larger than the shank. This type of bolt attains its tension by stretching the shank. It should be torqued to 45 ft. lbs.
This post was edited by Owen Aaland at 18:04:58 02/18/12.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
