The little cup, back up washer and 0-ring are right inside of the threaded portion on that lower one . If it has none, no wonder it leaks. Has to have an o-ring inside for pin to seal on. If you have a service manual it will show how you pull the cup out of actuator. And, yes, you screw in to increase unlatching pressure. Here is how I do a quick adjustment of the pressure to suit my own needs. After valve is fully assembled, engine running, lower hitch all the way, put position control lever all the way down into action control which dumps most of the oil going to aux valve , pull valve to latch, then pull position control lever to raise position and valve should unlatch. Keep turning set screw in until it will not unlatch, and then back it off again until it consistently unlatches. You are supposed to use a flow rater of course but that is another story.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
