Only if you were planning on running the new pistons directly on the bores, if not, JB the crack, let dry overnight, then sand/grind out the excess and install new sleeve, using some glycerine (local Mom & Pop style drug store) as a lube/sealant, but be quick to get it installed once you apply the stuff, because it will set up tacky in less than a minute. You may need to use substantial force to seat the sleeve all the way to the bottom. Try a block of wood and a sledge hammer. I have been running mine this way on number one since '09 with no problems at all, and I even tractor pull with it. The block can also be welded, if using sleeves again or not, as well, but will require boring afterwards. Might be a good time to bore that sucker out to what you think is a good size, then have custom sleeves installed in it, but this can get expen$ive. :P
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
