Posted by screwstick on January 09, 2012 at 08:25:33 from (174.24.15.42):
In Reply to: C-60 firing posted by KP2n LA on January 09, 2012 at 08:17:43:
The cylinder are numbered 1-4, front to back. With the front pulley on the timing mark, either 1 or 4 will be at TDC on the compression stroke.
Remove the #1 spark plug and with your thumb over the hole, rotate the pulley till you feel the pressure (compression) building up and continue to rotate the pulley till the you reach the second timing mark. You will now have the #1 cylinder TDC on the compression stroke. With this set, look over to the distributor rotor button, it should be pointing to the #1 tower, or about 1 or 2 o'clock.
This post was edited by screwstick at 08:28:39 01/09/12.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
