Posted by sgtbull on December 15, 2011 at 16:41:58 from (163.191.228.254):
In Reply to: Brakes on H posted by dcpky on December 15, 2011 at 16:11:47:
Once the bolt and washer are off, the brake drum should slide straight off. Its not a tapered shaft, so it is most likely stuck w/ a little rust or just crud. If your seals are leaking, its even less likely to be rust. A pair of prybars, carefully applied on opposiste sides, will usually pop the drum off. If that fails, reinsert just the bolt and use a two jaw puller.. carefully. The seal can then be pried out by driving a sharped old srewdriver (a big'un) through the side of the seal and prying it carefully, but firmly. You'll totally destroy the seal, but don't worry, you're replacing it anyway. Just be careful not to damage the shaft or the seal housing. DON'T take the cap screws out thinking you're going to remove the entire housing. It won't come out unless you're inside the tranny and have takent the bull gears loose. If anything, make sure they're good and tight. New seals are much thinner than the old ones, and you CAN double up on them, but the newer seals are so much better, one seems to be adequate. Just try to position it to a depth wehre it doesn't run in any groove worn by the previous leather seal on the brake drum. Make sure you put a dab of oil/grease on the portion of the drum that goes into the seal so you don't accidently fold the lip of the seal back and knock the spring off. Good luck! Its not a difficult task, and is time well spent. BTW, if your brake bands are just oil soaked, but otherwise not in bad shape, you can burn the oil off w/ a torch (outside, away from flammables), as the bands should be fireproof. They can be reused then. Do ONE side at a time or be very careful to not get parts swapped from one side to the other. The actuators are side specific.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
