The Hs and Ms were shipped from the factory with the cast wheels "dished in" to make the tractor as narrow as possible in order to fit more of them on the rail car. The dealer then simply swapped the wheel/tire assembly from one side of the tractor to the other, to achieve the "dished out" stance, which was required for MOST rowcrop operations. Simply swapping the wheels from one side to the other DID leave the non-removable lugs on the outside, and the removable lugs on the inside, which makes removing the rim/tire assembly nearly impossible. The answer is to get busy and completely remove all the lugs, bolts, and nuts, and then reassemble it the way YOU want it.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
