Posted by John T on December 11, 2011 at 10:19:31 from (173.243.181.15):
In Reply to: Super C coil issues. posted by Agricon on December 11, 2011 at 09:13:36:
If you were to put a test lamp on the coils input (NOT to distributor) terminal (other test lamp lead to frame ground) and turn on the ignition, THE LIGHT SHOULD LIGHT AS VOLTAGE SHOULD BE PRESENT
HOWEVER if the tractor is just setting there not running with ignition ON and you put the lamp over on the output to distributor terminal ID EXPECT IT TO BE OFF SINCE THE POINTS ARE LIKELY CLOSED THEN.....(if alls wired up correctly and the points are working good and closed)
If you turn her on and crank her over a test lamp on the coils output or distibutor input (from coil) terminal should flash ON (points open) and OFF (points closed)
Heres my Ignition troubleshooting procedure, give it a try
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
