Posted by LJD on December 10, 2011 at 05:44:17 from (67.142.130.17):
In Reply to: Magneto question posted by Machine249 on December 09, 2011 at 17:27:55:
It takes an extra 2000 volts to jump across the rotor to the pole inside the cap if it's new and clean. So if the spark is not as strong as it should be, you can get it out of the coil but not through the cap.
Easy test is to get a big spark plug and break the ground electrode off of it. This way the spark has to jump a 1/4" gap. If that works from coil with a 1/4" blue spark, you know you have enough to got through the cap.
A clean plug gapped at .025" takes around 8,000 volts to fire. If run through a distributor cap and rotor it takes 10,000-11,000 volts.
Gap a plug at 1/4" and it will take 20,000 volts which any good battery coil can make.
Also, points timing must be correct. If you points cause spark when the rotor is inbetween distributor poles, you can lose spark. If points are timed right, the rotor will point at a pole when spark occurs.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
