Posted by JRSutton on December 04, 2011 at 18:10:15 from (75.130.109.233):
In Reply to: M still not running posted by Todd Heck on December 04, 2011 at 14:02:57:
Have you tried turning the gas off yet?
Sorry to keep pressing the point, but I've re-read a few times and see no mention of you trying it.
(although with my A.D.D I often miss details people type, sorry if that's true here)
Just shut the gas off and keep it off. Keep cranking on and off for a good 5 minutes. While the gas gets used up, you'll eventually pass a point where the mixture is just right and it should at least fire a few times.
If nothing - drain what's left in the bowl - pull and clean the plugs.
Try starting it with everything dry using starter fluid only - no gas.
(I think you said you did this without the carb in place, but that might be a little too wide open -- and definitely use starter fluid, or carb cleaner if you don't have the fluid. Spraying gas alone probably isn't enough)
If it goes with the starting fluid, you can be fairly certain it's a carb issue.
If not it's probably a timing/spark issue.
If, like you said, you're getting a 1/4" blue spark, that's good, so most likely a timing issue.
A timing light should show any problems, even while just cranking the engine.
If you don't have a tdc mark on the crank pulley, just put one there yourself.
This post was edited by JRSutton at 18:19:09 12/04/11.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
