Take it one step farther. Remove the starter, leave wires hooked up, ground the starter to frame with a jumper cable and then try it to see if starter engages and runs. From your description of your wiring, you have not included the push button starter switch. Hot wire from solenoid should go to key switch, through key switch when turned on to push button, from push button (when pushed) to the s terminal on solenoid. The other small terminal on the solenoid is a ign bypass terminal used only on spark ignition tractor. If engine is stuck like you indicate, activating the starter will only damage starter and ring gear etc if repeatedly done. When you have starter off you will also have the best possible place to try turning the engine over by using a bar on ring gear.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
