Look at the shifter shaft and see if it has ware where it goes thru the top cover , next check the keyway in it . Look over the shifter cam and see how bad the detent slots are. Check the reverse shifter lever for loose pins and the shifter rod going down into the reverse shifter fork for a loose fitting key. No doubt that the cover is worn in the shifter lever hole and also the rev lever hole . Myself i have never bought a top cover as i had a machinist that would bore them out dead center of the holes and rebush them with a bushing and do it for forty bucks while i waited. Also replace all the headed pins and ya may need to take the shift lever off the tractor and have it rebushed also as i have had several that were plum slap wore out and had to redo the dash support also .
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
