Posted by big a on November 25, 2011 at 22:42:28 from (98.23.142.32):
Been screwing around with this for about 6 weeks now, in my spare time, and getting nowhere.
Tractor has been sitting for about 10 years, so I have no idea how steering really ever did work on this. Initially, I had hard steering both directions, but was somewhat easier to the left. System will make about 900 psi in LH turn, but only 100-200 psi in a RH turn. With the front end off the ground, the steering wheel turns freely, so I don't suspect a mechanical issue, like binding anywhere.
I suspected that the problem was in the steering control valve, so I removed it and dissassembled it for inspection. No problems found, and I reassembled it and reinstalled it. Now it turns easily to the left, still have the same pressures, and still hard to steer to the right. The steering shaft is free to move in and out, and seems to activate the valve in either direction, so I am not sure where to head next. Inspected the hyd filter, with no blockage found.
Sure was hoping to find that nut loose, or the spring broken, but no such luck. Any ideas as to where to look next? That difference in relief pressure between left and right really has me stumped. Is it possible that I have internal leakage within the front bolster itself?
The fact that this worked better after I had it apart makes me think the problem may be within the control valve, but for the life of me, I can't see a thing wrong with it.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
