Posted by Elden Russell on November 21, 2011 at 06:31:11 from (209.169.201.218):
I can't get oil pressure on my F 20. I have taken the oil pump out - every thing seems to be working. I blew out the lines with air and every thing is clear. Apparently the valves are not lubricated from the oil pump as there is oil caps on the valve cover to oil manually. I took the port cover off and turned the engine with the crank and the oil trough and scoop seem to be lubricating the piston bearings on the crankshaft. The only other part that should need oil is the govenor which gets oiled when adding oil. Can I run it this way? I am new at this. Any hints?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
