They do two things. neither one of which makes a lot of difference to the engine on a tractor. The first is that they can either increase the spring pressure for higher RPM operation, or repair weak springs to Specific Compressed length pressure. The second is that they have small contact with the spring metal which (in theory) reduces heat flow into the spring. There is not much heat on the spring from either the valve stem (cooled by the guide), or the head, (cooled by water). Thus the oil is likely to be the hottest thing around the spring, and well withing the springs lower critical temperature (at which it will loose temper) Shimming weak springs is OK using good springs is better. Using heavier springs on a Farmall (not a Puller, just a working tractor) is a bad idea, they do not float valves! Cam wear and lifter wear will increase dramatically with heavy springs. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
