Posted by Bob M on November 11, 2011 at 15:50:50 from (69.207.87.100):
In Reply to: super h belly pump posted by ajdeereman on November 11, 2011 at 14:38:29:
Removal is fairly straightforward:
- Remove the operating lever, and unscrew the filler pipe and (3) hydraulic outlets
- Remove the dust cover under the belly casting, then remove the pump drive shaft. (Pull the large cotter pin from either end of the shaft then slide the coupling sleeve back to disengage the shaft)
- Support the pump with a suitable saddle jack then remove the (4) 3/8" cap screws from the pump mounting flange. Now lower the pump from the belly. BE CAREFUL! The pump is top-heavy and will "flop and drop" if lowered uncontrolled!!
Alternative to the above step: Get a couple 2' lengths of 3/8" threaded rod and two nuts. Remove two of the cap screws from diagonally opposite corners of the pump flange and replace with the threaded rods and nuts. Run the nuts just snug to the pump flange. Now remove the two remaining cap screws, then lower the pump by gradually turning down the nuts on the threaded rods.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
