Posted by equeen on November 06, 2011 at 05:21:11 from (209.102.248.236):
Yep, I'm an elementary electrical(Pre-K) sort of guy; but here are the questions:
1. IH "Out to run", "In to stop" ignition switch has two wiring terminals. I see no markings identifying either terminal in any way. Thus, is it proper to wire from the ammeter to either ignition switch terminal, then all other wires to the other terminal?
2. I've seen a wiring diagram of a fuse in the wire between "BAT" on alternator to the ammeter. Is this necessary/helpful? If so, what type of fuse/holder?
3. Alternator #1 spade switch wire to ignition. Wiring options appear to include somewhere along the length of the wire: A filament style marker lamp bulb, or A 15 ohm resistor, or A 3 amp 50 volt PIV diode
Of course I could be confused with the above, but my question remains...... What is the purpose of something in this stretch of wire?
4. And, while I'm at it... how do I properly wire the original Delco Remey light switch (photo above)on the Farmall?
Term 1... Term 2... Term 3... (Is the #3 post on the L shaped piece of metal with 2 screws in it including the screw for #1 post?)
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
