Posted by glennster on October 28, 2011 at 10:16:45 from (76.224.4.21):
In Reply to: cub missing posted by Skipster on October 28, 2011 at 09:24:46:
if the cam gears are off, it will run bad all the time. i looked back a couple pages to see what else was going on with your cub, and i see the water in the exhaust post. if it runs good at times, then doesnt, i would re examine the ignition system and fuel system. disconnect fuel line from carb and let it run in a can for a few minutes to be sure you have good delivery and no sediment plugging stuff up. you have a new carb, so hopefully that is ok. do you have a mag or distributor ignition? recheck cap and rotor for damage, also re-check points and condenser. then wiggle distributor shaft side to side and check for worn bearings in the distributor. clean up all the electrical terminals if it is a distributor ignition. start at the dist and work back thru the coil, then to the ignition switch,then on to the battery power. try also running with the air cleaner tube removed from the carb, in case that is plugged up.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
