Re: transmission dope
Posted by JRSutton on October 26, 2011 at 13:12:32 from (75.130.109.233):
In Reply to: transmission dope posted by Von Anderson on October 26, 2011 at 11:11:17:
Not sure what you mean by "dope"... but since there's not too much you can put into a transmission other than oil -
I'd say between 4 and 5 quarts.
4 if no pto/pulley
4.5 if pto no pulley
5 if pto and pulley.
If you've never checked it before - your best bet is probably not to bother checking it - just draing it and put fresh stuff in.
Drain it by the plug found near the rear, bottom of the transmission.
You might also want to flush it out while you're at it.
Just drain it - fill it with kerosene (a gallon or two) ride it around in a few circles - drain it again - then refill with 90 weight lube.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
