Posted by wayne in mn on October 25, 2011 at 19:18:26 from (24.179.162.165):
In Reply to: Farmall H Carb posted by Pat Connors on October 25, 2011 at 08:20:29:
As a starting point: high-speed mixture screw set at 3 turns out, idle air screw set at 1 1/2 turns out. Start the engine & warm it up in NEUTRAL and BRAKES LOCKED. Run at WOT (wide open throttle) and turn the high-speed adjusting screw in & out to find the "sweet spot" where the engine runs its fastest & smoothest. Turn this high-speed screw out an extra 1/2--3/4 turn for power. Idle the engine down & set the idle rpm's. Now turn the idle air screw in to richen, out to lean so the idle is smoothest (this is an AIR adjusting screw so works opposite of the main fuel screw on the bottom of the carb). Re-adjust the idle rpm's. Repeat the carb adjusting procedure another time to be sure all mixtures are correct.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
