Posted by IH fan on October 21, 2011 at 07:12:58 from (99.151.33.39):
In Reply to: 350d utility posted by Jim Becker on October 21, 2011 at 04:39:19:
Strikefalcon said: (quoted from post at 06:39:19 10/21/11) Hi I'm looking to buy a 350D utility. I am not sure of the termanology. What is mean't by "fast hitch". "quick hitch" and What is the differance 2 pt vs 3pt.
Thanks
Fast Hitch is the hitch IH came up with in the early '50s and first used on the Super C. The idea was the implement had 2 "prongs" that the tractor could just be backed into with blocks that dropped into place to lock on the implement. In theory, you didn't have to get off and on the tractor to switch implements. A year or two later, it was enlarged and addapted to the larger 300 and 400 series. If you plan to use 3 point implements with a Fast-Hitch, you will need either the IH produced F-H to 3 point kit, or some form of adaptors. Quick hitch, is kind of a generic term tha some use for the Fast Hitch and some use for the 3 point system where instead of the "balls" on the ends of the arms, there are hooks so you can just back the hooks under the 3 point implement pins and pick it up.
My dad bought a new '54 Super C with F-H when I was a freshman in HS and the "back in and go" thing worked good for the heavier implements like the plow and disk, but lighter ones you usually had to get off and jockey them around a little.
If you are planning to buy a 350 or any tractor with Fast Hitch, you might want to check out the availability of F-H implements before you buy, otherwise you will no doubt need one of the adaptor types. I have an IH 240U with the factory 3 point kit on it.
This post was edited by IH fan at 07:14:55 10/21/11.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
