Posted by Red Mist on October 10, 2011 at 13:36:42 from (67.142.175.27):
In Reply to: farmall m carburetor posted by 1951g on October 10, 2011 at 08:01:29:
Old is exactly right. These are gravity feed carbs so every minor malfunciton with the floats, needle and seat are clearly visible to the eye - and ground. A stuck float on a system with a fuel pump does not show itself visibly nearly so often, since gravity is not allowing fuel to pour through the carb.
That said, ususally when you get them started and drive them a little, the bouncing around and vibration of the engine corrects the malfunction and they are fine - until next time it happens. For that reason, I don't run my carbs out of gas. I do shut off the fuel valve, however. Why? Because just about every time I run them out of gas, the float sticks at the bottom of the bowl and they are pouring gas when I open the fuel valve. Now, if I were going to park the tractor for a couple of months, I'd run the carb dry and deal with the stuck float when I restart them. But, I run my tractors more frequently than that and I've found I have less stuck float issues by not running the carbs dry.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
