Engines stop with the pistons in one of two places on a 4 cyl, and one of 3 places on a 6. This is where the the piston enters a compression stroke but stops before it completes the task. another cylinder that didn't fire was on compression but went over tdc to power stroke (with no spark) but expanded the compression air, pushing down that piston. The points are normally closed at that engine position (midway between strokes and stopped). If the Key or ignition Switch is left on, the coil will get full voltage 100% of the time. If running the coil is "on" less than 1/2 the total time (dwell). And the air is moving around the coil when running. A coil takes about 10 minutes of this torture before getting very hot. It may be just fine, if it works and makes reliable spark, no issue. The plug wires must be in the 153624. #1 toward radiator. Set #1 at TDC by pulling #1 plug, putting your thumb over the hole, and bumping (quick on off of start position) the starter around until your thumb feels compression, then turn the crank till the pointer is on the TDC timing mark. No figure out where the rotor is pointing and reset the timing. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
