Okay, heres the deal, on a 12 volt tractor you can do EITHER:
(Short answer to your immediate question: YES, if you use a 12 volt coil, remove the ballast)
a) Use a 12 volt coil (some call internally ballasted) with NO EXTERNAL BALLAST RESISTOR between the ignition switch and the coil
b) Use a 6 volt coil WITH AN EXTERNAL SERIES VOLTAGE DROPPING (12 to 6) BALLAST RESISTOR BETWEEN THE IGNITION SWITCH AND COIL.
NOTE an Ignition Switch must obviously supply 12 volts to a 12 volt coil ONLY when switched ON but not when OFF DUHHHHHH Some mag kill switches supplied a ground to the mag when OFF but no connection to the mag when ON. YOU NEED AN IGNITION SWITCH with a hot BAT voltage input connection and then the IGN out terminal goes hot when its switched to ON
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
