Posted by kenneth house on October 05, 2011 at 13:45:39 from (173.242.240.24):
In Reply to: H Won't Fire posted by George Rausch on October 04, 2011 at 17:19:20:
if you have a check light or voltmeter, turn on the ignition switch; you should have 6 or 12 volts (whichever system you have) at the coil. if not you have a bad connection, switch etc.
if you have voltage at the coil, you could need a set of points, or ignition coil.
to test the coil remove the short wire going to the distributor, from the distributor. remove the lead wire going from coil to the distributor, replace it with a spark plug wire and insert spark plug and ground the spark plug. then be sure that switch is on and drag the short distributor wire across ground. if coil is good, you should get a spark across spark plug.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
