Use a test light. they are ~2.50$ They look like a small screw driver and have a wire attached. The power should be found at the wire supplying the fuse, both ends of the fuse, the bracket of the fuse holder to the switch, the wire connecting to the lights, and at each light. Poor connections at any point will thus be evident. The dimming resistor on the IH light switch must be good to have Dim lights. If it is not good, there will be no voltage for the test light on D position. If the tractor is equipped with light bulbs or sealed beams from other applications that draw more watts than the original, the D position will burn out the wire resistor in a flash. the switch is not good for much more than the original lights, unless run through a power relay to avoid over loading the switch contacts. Keep us in the loop. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
