Posted by BUCK CLAYTON on October 01, 2011 at 20:45:52 from (70.189.97.146):
This tractor has always had a stiff area when starting in one area.Has to have a good battery to crank a complete revolution. Mag. was set on #3 {4 o'clock] instead or #1 and this is how it ran when I got it.Am in process of restoring and have everything off from behind motor to back of tractor.[tank,steering & seat]. Today took all spark plugs out and jacked up rear wheel to match up #1 piston with mag click. Timing advanced 1" past second pully mark.Got mag set only to second mark, but when rolling tire around I still hit this real hard place . Same problem as when starting with battery. What could this resistance be? Trans. and rearend not causing this because with clutch in and cranking with battery ,it did the same. Tractor also has orgional mag. with cable switch and you can rock rotor quarter inch. Rotor does not fit slot in mag shaft. New one does same thing. slot not walowed out. Tried to give all info, sorry for so long. I do need help. Thanks, Buck
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
