Re: F 12 valve timing
Posted by 36F30 on October 01, 2011 at 15:28:30 from (71.38.169.170):
In Reply to: F 12 valve timing posted by Craig45 on October 01, 2011 at 14:22:49:
Page 33 of my 1935 F12 instruction book says to set valve clearance at .016. It says nothing about them being set hot.
To check the valve timing first set the valve clearance as above and then with number one piston at TDC rotate the engine just to the point all play is taken up in the intake valve lever. Then look on the flywheel there is an I/O mark on it and it should be within 3/8" either way of the timing mark on the bellhousing. If its not, your out of time and I would look at the front crank gear, I have found a couple that ate up the keyway and were loose enough to affect the valve timing.
This post was edited by 36F30 at 15:30:11 10/01/11.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
