This is a classic example of what happens with a worn out MCV pump and a TA that has a worn out sprag clutch in the low side of the TA.
The MCV pump provides oil for the steering, brakes, TA, and TA and transmission lube, in that order. With no demand on the steering the oil just flows through and the pressure is regulated by the pressure regulator valve in the MCV to about 250 PSI. When the steering is put on demand the pressure rises until the tractor steers or it open the steering relief valve at 1800 - 2100 PSI. In a worn out pump the flow drops off as the pressure increases. When the flow drops off the TA no longer has pressure to keep the clutches engaged and so they release. If the sprag was good on the low side the tractor would down shift to the TA speed but keep pulling. Because it stops we can determine that the sprag is slipping. When the pressure requirements for the steering drop off the TA again receives oil and the clutches engage again with a bang.
When you pull the MCV off the center section you may find a blown O-ring or it is possible that the flow divider valve is stuck but those conditions can be seen after things are apart. If other problems are found it is possible that the pump may be OK.
A bigger problem can not be seen when you have these conditions. The excess flow from the MCV pump is used to lubricate the range transmission and differential bearings. Since the steering has priority if you do not have enough pressure to satisfy the steering there is no lube flow through the oil cooler and the rear frame.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
