Re: Neutral Safety switch idea.
Posted by Janicholson on September 22, 2011 at 17:37:12 from (67.72.98.45):
In Reply to: Re: Neutral Safety switch idea. posted by M Diesel on September 21, 2011 at 16:14:42:
The bowl shaped rain cover at the bottom of the external part of the shift lever (with the spring holding it down is fixed in relation to the lever. In neutral, the front center edge of the bowl is, lets say, 2.5 inches from the platform deck. As the lever is moved left to right in the Neutral gate, the heght above the deck does not change as the bowl tips right, then left. This is the location of the roller on the safety switch (when on and conducting). As the lever is moved forward into any gear slot (R,2,4 on an H), the edge moves down to 2.25 inches from the deck releasing the pressure on the roller, and shutting off the Microswitch (open). If the lever is put in any gear that pulls the lever to the rear, (1,3,5 on an H) the edge moves up to 2.75 inches above the deck and again the switch is open. Remember thes distances are to be measured, not assumed to be correct. It would work on any tractor with this bowl shaped rain deflector, provided it has a gear pattern with a single straight line neutral.
Cubs, A, B, C, 300, 400, etc. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
