If the idle jet was drilled out the main jet may have been drilled also and some times when that happens you cannot control fuel even by turning the main jet adjustment all the way in as it does not conform to the taper on the needle. You should be able to kill the engine when running by turning the main jet needle adjustment screw all the way in. If you cannot then you know where to look. If you can it still might be the jet is over sized. I don't have the jet size in my head but it is about .050, and I have seen then drilled out to double that. All fuel has to flow through that main jet at all speeds and loads. It could be the main nozzle is messed up also but you would have to compare it to another one to tell. I am assuming air intake from air cleaner is not a problem but that is easy to determine with hose off air cleaner.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
