Posted by Indiana Ken on September 14, 2011 at 17:11:52 from (66.249.235.212):
In Reply to: Tire inflation posted by Shawn Osborn on September 14, 2011 at 09:43:19:
For fluid filled tires the pressure should be checked with the valve stem at the top, to eliminate/minimize the effect of the fluid on the pressure reading.
A column of water 2.31 feet high equals a pressure of 1 Psi. Therefore, if the valve stem is at the bottom, the pressure gage will read the air pressure plus the fluid head pressure. Water weights 8.33 Lbs/Gal and in the case of calcium chloride solutions the additional solution weight also needs to be accounted for. For example, with the valve stem at the bottom and checking a 38" tire filled to the top of the rim with a calcium chloride solution weighting 13 Lbs/Gal the fluid head pressure will be: [38In/12In/Foot] divide [2.31 Foot/Psi] times [13Lbs/Gal/8.33Lbs/Gal] = 2.1 Psi.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
